Hello
Wich cartridge is the best match with
this phonostage?
Could be the hana EL with 0.5 mv, a good match?
Thank you very much.
Nacho
Best match are low output MC cartridges, so the Hana EL should be fine with the Stageline S.
How about Stageline E?
The gain is less with an E, so you might struggle a bit with just 0.5mV.
Hello again,
To fits the stageline directly into a naim nait xs
Is necessary the 24v power supply?
Thank you.
No, you can use the powered aux output of the nait.
OK, thank you!!
