I heard that DIN cable gives better sound quality than RCA.
I have a Focal SOPRA 2 run by Supernait 3.
I am planing to to get a streamer so I can play from streaming and also my local collections including DSD (.dsf)
I am planning two options:
get ND5 XS2, connect to Supernait 3 with DIN Cable. In this case it will use DAC in the ND5 XS2.
get Holo Audio Spring 3 (preferably L1 so can save some money, but if sound quality doesn’t match with Supernait 3 and Sopra 2 then I can go for Spring 3 L2 or KTE) and use good quality RCA Cable (Audio Sensibility) and USB (Audio Sensibility) to connect temporarily from my Macbook Pro to Spring 3 with USB. Later I can buy Aurender N100 for the streaming.
In option (1) I can use DIN Cable and in option (2) I have to use RCA.
Can anyone suggest which option will give me better sound quality?
thanks
