Hi, I have the possibility to buy a naim supercap built in 2004. I would like to know if from 2004 to the introduction of the dr variant, it has undergone substantial changes, and what I should check before buying. Thank you
If you look at the link below you will see that a 2004 model was not built as DR, but it can be upgraded by Naim. If you think it has been DR’'d then to confirm, your best bet is to get the serial and call Naim who will tel you if it has been done and well. They can probably tell you its service history also.
