Hi all, have just started using a uniti 1, updated etc, couple of things i need clarification on.
I have a hard disk connected to my router, when i select upnp the tracks on the disk are listed, i can scroll through etc but can’t play them, any suggestions?
This is more simple (if you know) the balance control doesn’t read L/R but rather +/- the handset doesn’t really help either as it adjust up/down. Anyone know which is left or right?
TIA
