Connected the BT ariel to the rear, chose BT on the input, Connected to my laptop correctly, pressed play on Spotify for a test run, nothing, no sound.
What am i doing wrong?
Sorted, sorry.
If you use Spotify Connect you don’t need Bluetooth. Control the streamer from within the Spotify app, and use a more reliable network connection instead of BT.
Yes, i know, Wifi is far better but i picked this up a few days ago so needed to test all the inputs/outputs.
