I have purchased Naim Uniti 60DB.
Can I try to dream through it listening Tidal?
60DB? What’s that?
Can you confirm the Uniti model you purchased, name should be on the back or upload a photo of the unit.
I would guess that minimum volume shows-60dB?. Are we talking about the original Uniti here?
Has your Uniti been updated to 24/192 with the later streaming board? If so, you can stream Tidal. Just make sure the firmware is up top date. However, if it’s still in original spec then you would probably need to use an off board device able to stream tidal to the Uniti’s DAC, or else have the Uniti updated to 24/192 spec.
https://www.naimaudio.com/connection-magazine/21591/say-hello-to-tidal
