Hello. I have a question for Uniti and AirPlay users. Does your equipment sometimes not show album art when playing music via Apple Music AirPlay? This happens sporadically during some tracks. Sometimes, for example, in one song in the middle of an album.
Have you tried turning it off, removing the power cord and then rebooting after a few minutes? I’d try that if you haven’t.
I turn the device off every night.
Turning it off with the button on the front (which I am guessing is what you do) isn’t at all the same as Mike is suggesting…
I disconnect it completely from the electricity.
You need to remove the power cord and then reinsert after a few minutes to reset the unit. That will clear most issues.
I’ll try, but as I wrote, I unplug the device every night by turning off the power strip. It’s probably the same thing. I also did a factory reset. I checked now and the same problem in Spotify using airplay. Every now and then there’s no cover. Sometimes for a moment, sometimes while listening to the entire song.
I tried. Still no change.
Okay, how are you accessing Airplay? If it’s iOS, try a hard reset of the device.
iOS. I have the latest update. I tried with two iPhones and an iPad. Always the same. I tried with 2,4 and 5 networks and via cable.
Okay, I don’t know anything else to try. I vaguely remember this happening with Apple Music occasionally, but I rarely use Airplay. I suspect it’s an issue with Apple rather than the Atom.
I tried Spotify via airplay today. Same thing.
