When I turn my naim uniti atom Headphone edition on for the first part it loads up as normal for the second part, it starts updating has anyone got any idea what is going on.
Is it connected online, preferably wired?
Have you done a proper power down? Hold down the power button for 10s. Wait another 10s before restarting.
Edit: sorry. HH has it exact below
To do a full restart, it’s a case of pressing the power button for three seconds to put it into deep sleep, then unplugging it from the mains.
It’s running wireless mate it would do it every so often.
I will try that now, mate.
Everything seems to have turned on properly.
Sorry folks, it’s doing the same thing again.
I reset everything and it is still doing it.
I done what you told me to do Still the same thing happening.
Email Naim support?
I didn’t do a factory reset properly so I did it again with my friend with me everything seems to be working great thanks for all your help.
