Hello ive got Naim uniti Atom and Aria 906 i buy today sub SVS 2000 PRO and cable is https://www.qed.co.uk/qed-performance-subwoofer-cable.html#tab0 ive connect it to the output left into sub input left one cable!
from SVS they tell me you will need to connect the left and right audio output of the Atom into the left and right input on the back of the subwoofer. This will transfer a full range audio signal into the sub so you’ll need to turn on the Low Pass Filter in the subwoofer and set it to the frequency where the sub blends best with your speakers.
I need to buy second cable is that right?
