Naim Uniti Core can’t find metadata
I have a Uniti Core that has worked without issue for two year. Then last week, I inserted two new CDs to rip to my NAS and the Naim was unable to identify either. They both read as “unknown”. I rebooted the unit (including unplugging for a bit), but the problem persists. If anyone has suggestions on what to do, please let me know. Thanks.
-Andy
There’s a thread like this most weeks.
Software on the Core really not very good.
I find the Core usually deals with the metadata without any issues. If it doesn’t find the metadata first time retrying a couple of days later has on occasion been successful. I don’t listen to a lot of classical, so when the metadata and cover artwork don’t load, I just edit it in the Naim app. It usually only takes a couple of minutes to do that. It’s a tad frustrating but works well for anything in the jazz / rock type of genre. I’d be less happy if to had to try to edit for classical though. A bit frustrating if you forget to press “Save” at the end of the process also.
