Naim Uniti Nova and HDMI ARC
Hi.
I have trouble getting the Nova to recognize the HDMI cable, so there’s no sound from the TV and therefore no ARC function. When I switch the same cable over to my Bluesound Powernode 2i, everything works as it should. Any advice?
Edit: It’s a Samsung TV.
I had the same issue, and chose to use the optical for sound from TV to Nova.
The tv…. Is it Samsung?
Recurrent issue ( regarding HDMI)
You are exactly right, it’s a Samsung.
Unfortunately. Don’t know if software update s will heal this.
But I’m not in the know.
Maybe madame @Naim.Marketing can give some light on the matter
I would strongly suggest contacting our support team, with all the details - they are logging them all so we can work on updates
Thanks Madame, for the sympathy/ availability ( once again)
I’ve sent a mail with the Samsung model number.
