I am currently listening to Naim Uniti, specification …
two options 50W per channel into 8 ohms and 90W per channel into 4 ohms.
Decided to buy a new Naim Uniti Star, but it only one… 70W per channel into 8 ohms.
Is it possible to connect 4 ohm speakers to each chanel? (Naim Uniti Star)
Thank you very much
Short answer: yes, you can.
Long answer: The nominal impedance of your speaker does not matter, as it is not a fixed value and just gives you an idea about its design and how difficult or easy to drive the speaker potentially can be.
