Naim Uniti Star - Time Format in 24h
Hello Chaps,
I’ve changed my Uniti M1 to a Uniti Star.
How can I switch the time display to the 24hh display?
Thks for any hints
Martin
I have never found a way to do this. For some reason, Naim hasn’t included this as an option, or if they have, I never found it. I don’t think you can change time to the 24-hour format on the New Classic range either, which I find a bit irritating. This simple change in the firmware would make me a happier Naim customer. Since buying my Star several years ago I have never understood why the 24 clock is not the default setting.
That, and why it’s only possible to show the clock using the remote? Why isn’t this available via the app?
… and the 24h clock was workin with my Uniti M1, bought round 2010 …
Martin
And the clock doesn’t account for summer time in New Zealand, so it’s an hour out - even though it’s meant to read from the web…. It used to work properly.
