I have just upgraded from an original Uniti All in One to Uniti Star.
I have a NAP200 from my previous set-up and so would like to compare the sound of the Star with and without the NAP.
The original Uniti had a feature where you needed to “switch off” the speakers, but I can’t seem to locate the same on the Star. Does anyone know if there is one on the Star?
Also would the speaker cables go through the Star or NAP?
You don’t need to tell the Star that you are connecting a separate power amp, it will automatically switch to the pre out. You will need an RCA to 4 pin DIN lead to connect the power amp, then just connect your speaker cables to the 200 instead of the Star.
