Looking for some opinions as to whether the uniticore is worth the money Vs spending money on a good USB SSD and hi-end USB cable to connect. At half the cost would I get the same audio performance connecting a drive to my Atom? Or should I just take the plunge and get the Core?
I’m not convinced that you need to spend much money on a USB drive for the Atom. Cheap drives or memory sticks work just fine for me.
Personally I wouldn’t buy a Core. For that money you’d get a far bigger upgrade by trading the Atom for a Nova.
What the Core gives you is storage that copes better with a large library, and a CD ripper of course, but I think you’ll find you can get this with much better functionality for far less money if you look elsewhere. For example, if you want a simple, ready to use device, an Innuos Zen Mini at less than half the price of the Core is hugely more versatile. For considerably less money than that, a traditional NAS/UPnP server would do the job very well for £300.
