Naim unity 2 now only plays 1 track instead of all
naim unity 2 now only plays 1 track instead of all
always been able to stream music from pc to unity 2 but today it will only play 1 track from all
anyone any idea to fix
thanks
Iain
You need to give us more to work on.
Where are the tracks coming from? If you are streaming from the internet then how is it connected to the internet?
What firmware is your Uniti 2 on? It should be 4.8
How are you controlling it? The Naim app? IOS or Android? Or are you just using the remote?
But if you haven’t tried anything to fix the problem yet, then the first thing to try is taking the power off the Uniti 2 and then plugging it in again. If that doesn’t work then restarting your router and your Uniti 2 is the next thing to try.
