Naim Update
Hi - My Uniti Nova has been updating for the last 24 hrs. Anyone else having the same issue and should I be concerned? Many thanks.
It will have got stuck. If it were doing an update, it would only take 10 mins or so.
I suggest disconnect it from the power supply, leave it off for a couple of minutes, then plug it back in and let it restart normally. If there is an update that you haven’t previously let it do, then it will find it and hopefully this time will finish normally.
Many thanks David. I’ll give it a go
Thanks, David - back in operation!
