Naim volume potentiometer
Hello,
Have had my NAC 202 serviced ,so far so good.
Just I hear low music when set to 0 through ATC scm11, is that safe ? thanks
If it’s a very high level output from the source then you may get a very tiny bit of signal (it doesn’t fully mute at lowest volume setting) coming through, but you would have to have your ear right by the speaker to make anything out and mostly it would be drowned by the low level hiss.
hi Richard thank you using nd5xs , my lady and I perceive it even though not close to the speakers, just as a background noise .
It doesn’t happen with the analog rig, though :slight_smile:
Does using the mute help?
yes it does
OK, that’s good.
thanks Richard
Always hyperhelpful
