Hi there,
How do you connect a separate pre-amplifier to the XS2 i.e. using the XS2 as a Power Amplifier. The Manual states it DIN carrier 24V as well, the ch1/2 is the easy part but wat should be connected for ground -ve? Want to avoid blowing the pre-amp
Kind regards, Emil
From the manual;
Note: When an external preamplifier is connected to
the Nait XS 2 power-amp in socket, a fault will initially be
indicated by the Nait XS 2 mute button flashing. To clear
the fault, press and hold the flashing mute button. This will
un-mute the amplifier and turn off the display and volume
indicator.
Note: The power amp in socket carries a 24V DC power
supply output intended for Naim preamplifiers that require
an external power supply.
