Nait 1 and LP12/Prefix connection?
Is it possible to connect a LP12 with prefix (din connector) to a Nait1?
In that case, is it through Tuner or Tape input?
The usual consensus if out of inputs then the tuner is the default second choice. :thinking: :+1:t2:
IIRC, You’ll need a power supply like a Hicap for your Prefix to plug into. You will also require 4 to 5 pin din interconnect to plug the Hicap into your Nait.
Thanks för the clarification!
