Happy new year everyone.
Would I just need the headline amp and associated power supply to use headphones with my Nait 1 and LP12?
I believe so + cables of course.
The Headline comes with a suitable captive cable. If you use a NAPSC with the Headline then you’ve good to go, but if you use one of the bigger PSUs you’ll need a SLIC cable.
thanks guys.
