Yes, you need to cut those links to convert the RCA inputs from line level to phono. It will sound awful if you don’t. Just the two you indicate. Shielding may also be required…
Neil.
Edit: just to add for reference. It isn’t necessarily the correct course of action across the whole Naim preamp range. This refers to nait 3 and nac92 only.
Yup, shielding for MCs shouldn’t be necessary on the NAC92, but probably needed for the NAIT3. I’m not sure though whether Naim still supply the mu-metal foils.
My plan is to use/buy MC boards. (Current PU is a MM but i have an MC PU that i want to use)
How do i use the mu-metal foils?
Should I reconsider and use MM boards instead and contiunue using my current PU?
You’re best off not using the Mu-metal shield if possible, however, if you go for NA523K boards, it may be necessary. Main issue is that having a mains transformer so close to the boards can create noise as they have a very high amplification and are otherwise unplugged or shielded for best sound.
IIRC the mu-metal shield is stuck to the lid, but Naim can advise you further on this, and whether they can still supply the kit after so many years.
