Hi there people.
I’m new on here so a question you may have a heard before.
My Nait 5 remote is not always reliable with the volume inputs. It is reliable with all other input changes. However if I pop the battery cover off and just move the batteries slightly it seems to work. I don’t have to remove them, just rotate or tap them. Any ideas ?
Welcome.
Worth trying a fresh set of batteries…
I hope it works out for you.
I have done that. Problem persists. Seems a battery seating issue to a non tech person like myself.
Yup, sounds like a fresh set of batteries should do the trick here.
You could try cleaning the contacts in the remote and carefully bending them ever so slightly (be careful here though as you risk snapping the contacts).
Every day is a learning day.
Newish batteries removed and tested. One supposedly new battery very low in power.
All batteries replaced remote works fine. Thanks for the advice.
