I just noticed when I place my ear very close to the HF Horn of my left speaker there is a very faint buzz. Only on the left channel. It is incredibly faint and only just audible - but there. This is distinct from the usual faint hiss from Naim amps which in this case is incredibly low level and barely audible. The buzz is independant of volume setting and is as I say incredibly faint. I only have a CD5si plugged into the N50 and it could of course be originating form this. All cable dressing appears fine. Has anyone else noticed this?
I just checked and, I only have a normal level of very faint hiss coming from both tweeters.
From my right woofer I can also hear a very(!) faint buzz coming, but only if I almost have my ear to the woofer. So, I can’t be bothered/worried.
As long as everything sounds fine at normal listening distance from your speakers I wouldn’t worry too much Pete.
I understand it seems a bit strange that only one channel produces this very faint buzz, but I assume that listening with you ears very close is not your normal/prefered listening position. ![]()
If it concerns you why not try different input selections, and if only on the CD one try with CD disconnected? Quick and simple to try.
Yes I switched inputs and it’s still present. So not coming from the CD5si.
Thanks Alco. Yes it is extremely faint and only audible with my ear very close to the HF horn. It doesn’t matter in itself but my concern is if it’s symptomatic of some problem with the N50 that could cause wider issues and needs attention. Interesting you have it on your right woofer. Perhaps just a ‘thing’ with the N50 which is why I was interested to see if anyone else has the same or similar. I don’t really want to pack my N50 off for a hospital visit unless it’s strictly necessary. But equally as with ourselves it can unwise to ignore unusual symptoms.
I sent the first one I had back because of this. No such problem with my current one. For info I have a streamer connected.
I was just looking around on line and came up with this reply from @NeilS on the Naim staff to someone who had the same issue with a Nait XS2:
So I guess this probably clears it up. I hope.
Did anyone say what the issue was? Getting a replacement is not happening - for obvious reasons.
That sounds reassuring. ![]()
(btw, just checked if the faint buzz, from my right woofer, appears on all the 3 inputs of my Nait 50, and yes, it does. Still, this seems totally normal and for the same explanation NeilS gave I’m not worried at all.
No I just didn’t think it sounded right so they replaced it without question. I’ve just listened again and I can’t hear anything untoward. If it’s only faint and barely audible I wouldn’t worry.
Try swapping left/ right cables to opposite speakers, just to rule out it being the speaker.
It’s also worth getting some shorting plugs to put on the Phono input - being high gain it could be humming/buzzing with nothing connected and bleeding into the other inputs as crosstalk.
Simple test - if you select Phono does the buzz get worse ?
No - still the same.
I’ll try that later - but very unlikely in my view but yes needs ruling out. Just one possibility here. The LH speaker sits relatively close to the router/ONT box and associated SMPSs. Less than Im distance to the speaker, and the NACA5 passes even closer. The very faint buzz does remind me of the noise that SMPSs can induce. Not through the mains, but directly from the EM field they produce. So later I’ll switch off the router and see if it makes a difference.
OK I’ve ruled out anything to do with SMPSs or the router. Makes no difference. So I guess I’m happy to just accept @NeilS’s explanation and leave it at that unless something further develops. Having just got everything nicely settled I really don’t want to go down any more rabbit holes now.
There are reasons why big separate boxes have
advantages over small integrated…distance from the transformer is one.
I’ve got 2 NN50…
Both utterly silent ..
Speakers vary between ALCHRIS TX9, ATC, PMC..
Just a bit of an update. Closer listening has shown that although I thought the buzz was only from the LH channel HF horn it is also audible through the bass/mid driver. Also closer listening has shown that it is also on the RH speaker though much, much quieter here. To give an idea of the level on the LH speaker it’s faintly audible with my ear around 10 - 15 cm from the speaker. It’s more of a 50Hz buzz rather than a hum if that makes sense. I’ve heard the sort of hum typically resulting from grounding issues in the past and it doesn’t sound like that to me. It sounds more like the sort of thing induced from an external source such as from that radiated from a SMPS. I’ve tried switching off all other appliances on the same ring and it makes no difference at all so I don’t think that it is actually from anything outside the N50. But it’s more of a sharp buzz than a dull hum if you know what I mean.
This is worrying me now. Perhaps @Richard.Dane or @NeilS would be kind enough to give an opinion here. Is it what would be considered normal or acceptable for the N50 or is it something I should get checked out? Obviously if it is of concern then I need to get it addressed within the warranty period. Thanks.
At your age it’s probably tinnitus Pete![]()
Little noises here and there are quite normal for hifi equipment IME. It could be your cables, or equipment siting - have you tried changing them?
My approach to minute hifi noises like is that if I’m feeling anxious about it, just go and do something else until I’m in the mood for a good listening session. No good sitting down to listen when you’re ruminating on some system quirk.
