Hi, I have an original Nait 5i and there is very significant crosstalk between inputs, eg. selecting Tuner if nothing is playing on this input but the adjacent Tape has a live input, I will hear that through the Tuner input, at fairly high volume (say 1/3 of the regular level). Is this normal?
Are you sure the tape input is connected to the right pins? Sound like something may be paying into the REC out pins.
Hmm ok that’s embarassing - you’re absolutely right, I’ve been playing around with amplification and just recently tried out a friend’s Classé amp to see if its added power helped my new power hungry speakers (it did). Must’ve made a mistake in reconnection. Thanks for your help Richard.
