Just a quick question about the sub-outs on the XS2; my REL only has one RCA input, and I use a single RCA sub cable. If using the sub-out, which out should I use, L or R? Or pick up a 2 RCA To 1 RCA cable?
I have 3 options of connecting the sub; high level, Node sub-out, or XS2 sub-out, just want to try them all to see which I prefer.
Are you using the node in variable volume / preamp mode connected to the XS2 av bypass input? Just wondering how else you would control the volume of the sub connected to the node sub-out.
Yes, at the moment. I have a set volume on the XS2, and control the volume via the Node remote, including the sub. The same set up I was using with the 5si
You can get away with running the sub from either L or R channel as bass is not very ‘directional’ so the level will be similar through either channel. Better still with a Rel sub, use the high level connection.
