Asking for a friend, is there anyway to connect a subwoofer to a 5si? The sub needs alone out connection and has its own volume control etc
If the sub accepts high-level connection then just take a feed from the speaker terminal.
If the sub only has a low-level connection then I don’t think it’s possible to connect to a 5si.
What subwoofer does your friend have?
You need a sub with a high level input that can be taken from the speaker terminals. It should also be a 2 channel input, not a single channel LFE.
