Inspired by an image posted by Richard, i am in the process of building a Nait mini system inspired by the 80’s original below
Initial thoughts were the original looked to be built from foam sheets siliconed together? To improve on this, I have used 16mm black solid phenolic resin for the build. This gives a solid base for the components, the unit weighs around 5kg unloaded and also I can cut slots etc into the panels with a router.
In regards to the design, I thought it would be better to make it more universal by sizing the bottom section to take both tapes and CD’s. This larger size would also be handy if 2 shoe box size components are being used.
I have also routed a slot down the side the help with cooling and also act as a hand hold for moving the unit around.
In regards to the audio components, I will be using my Nait 2 as I don’t have a 1 and also unfortunately neither do I have a Sony WM-D6C. Looking at the prices for a good one of these, it might need a bit of saving to get this.
In its place I have a selection of Half size Sony components including the PS-Q3 half size TT.
Finally the speakers, I have sourced a pair of MK1 diamonds which should be with me soon.
below is the first prototype, any thoughts, comments on how to improve for the next one would be greatly appreciated.
This is just the best thing ever. . An obvious iteration would be a level for each source (TT, Tape, CD) for the ultimate stack with Pi behind the media. Maybe even a graphic equaliser?
Wonderful! I love the half-size pieces of equipment, they just have that certain je ne sais quoi about them. The old Naim stuff is so full of character.
Why not build some little isolation platforms with spikes/ bearings/ whatever? Never seen half size ones.
IIRC @Jono-13 used to run a half width (Tangent ?) CD player recased into a CB chassis which would be a neat addition to this little setup. I think it was in a classic CB system setup along with a NAT 101 and Kans.
I have posted elsewhere on the Forum that I am about to do something similar, making a compact bedroom system to replace a Tivoli ModelTwo system, which will be relegated to the kitchen.
It will comprise an n-Vi, a Nait 2, a NAT-02 and a pair of cherrywood Kestrel LS3/5As, which James at TomTom has ordered for me. I had considered making a 1970s-style cherrywood cabinet or case, but wiser heads have warned against this - concerns about heat dissipation.
