FWIW there are SN3 out there such as mine which are absolutely fine. Balance control dead centre. Volume centred at all volumes (although at the very limit of hearing I think there may be a minimal movement left but that would be taking listening at low volumes to the extreme!).
Good to know.
I previously has a 202, and at low volume levels the right channel would turn off. Turning the volume up slowly from zero you would hear left speaker then a little more turn the right speaker - sometime at higher volumes I wanted.
Now have the XS3 no such problems, fantastic amp
Pure speculation, I know, but I wouldnât be surprised to see that type of volume control migrate to the integrated amps and perhaps even the preamps in the long run.
Roger
My speakers are 92 db too, in 8 ohm. No problem with the 250 dr .
Well theyâve done it with most of the Unitis and Statement so I wouldnât be surprised either.
Dear Magnolia, I take your point as I had never thought of this.
Kind regards,
Mitch.
