Hi All
I am new to this forum.
I use a DSP between the Aurender A10 and XS2. I have connected the REL sub to the MiniDSP. The DSP is connected to line level AV input of the XS2. Because of that I have to use the volume control of the Aurender so that main speakers and the sub can be regulate together.
Now the question:
As per above diagram. if I use a 5 din 4 RCA interconnect plugged in to HDD (out /in), can I connect the Line in of the DSP to the HDD out and line out of the DSP to the HDD in?
Then can I use the volume control of XS2 to control the level in to DSP?
Thanks in advance
Priyange
