Agreed, Richard– it should come back on itself if that’s the case.
To the OP @vochoi , does this happen if you use a different source to the Metrum ? I note this is a NOS DAC so there is no output filtering and perhaps an excess of out of audio band HF noise is upsetting the NAIT ?
Thanks James, Yes I’ve tried to link vintage Philips cd player to N50 with Hiline, it nice playing whole CD ; and move to Metrum Pavane (NOS DAC too), N50 also in normal use. But,
the white light was still bright all day when no signal in.(instant on: on), quite strange!
I wonder… I can find some specs for Sommer Excelsior Classique cable and it’s highly capacitive compared to what Naim would recommend, the figure quoted being 125pF per metre. No idea what the inductance figure might be, but I see images that show it’s woven, which is normally done to lower inductance, and not great for Naim amps.
Yes Sommer Excelsior Classique EX42.
i’ve found these info but EX4K:
The EXCELSIOR® classique 1 XLR 1 consists of two combined, opposing wire pairs (crossover) with 4 x 0.20 mm² each. That way we achieved an extremely low capacitance of only 37 pF per meter which enables a super low-loss transmission (even with excess lengths). A tight stranding technique and fine, oxygen-free copper wires ensure a homogeneous, linear and pure sound image. Moreover, the cable has a tight multiple shielding with a 100 % degree of optical coverage. Each channel was equipped with a tin-plated helical CU screen and an AL/PT foil. In addition the cable has an overall screen of tin-plated CU cross-braiding. Thus the cable is perfectly protected against external interference.
I confused that, the capacitive of speaker cable can lead the shutdown problem?
i’ve just 1 pair cable for the Falcon, Excelsior Classique EX42.
we compare the nait50 and CB nait2 tonight, N50 much better than CB N2, More refined high frequencies, broader low frequencies, and a denser midrange. A stronger sense of control. In comparison, the N2 sounds somewhat harsh. (Of course, the N2 has not been maintained.)
The Phone in N50 especially good!
Sommer EX3V
Miscellaneous:
Capacity wire / wire at 1m: 125 pF
Inner conductor: 2 x 4,0 mm² [AWG 11] with a stranding of 225 x 0.15 mm
Insulation: PVC 3.5 mm
