I chance upon a pair of Chrome Bumper NAP 135 for sale and would like to seek advise on:
The front doesn’t seem to be something I recognize as there is no logo, (attach a picture) would like to find out if there had been changes changes over the years to the front?
I will definitely send them off to Naim for a full service, I understand the H&F transformer has been discontinued so a Nuvotem is preferred? but is there any thing else to take note when buying a 135?
As I have more Olives I am alright to wait for a Olive 135 to pop out.
Thank you
The front panel has presumably been replaced at some point as the Naim logo is missing. That makes me wonder what else might have been replaced with non-standard parts. Does the seller have any information?
The front panel is definitely not original. Some of them could become quite brittle and it was easy to fracture them or break edges off if you weren’t very careful sliding out the tray from the sleeve. That may have happened here and someone fashioned a replacement. The good news is that Darran at Class A received permission from Naim to have some new fascias made, so provided they aren’t all gone already (Naim had some too) then you should be able to get it restored at the same time as getting it serviced.
As Chris has mentioned though, you may want to find out whether anyone has fiddled about inside. Naim will return it to standard, but if there are any modifications then it may get costly.
The front fascia panels on the early Naim amps are very fragile. It’s all too easy to damage them during disassembly if you’re not aware of this. Replacements are rarely available and stupidly expensive when they are.
Managed to check again. The units came with the front panels shown from Absolute Sound (only dealer for Naim in Singapore) and their serial numbers are running 195xx - meaning that they are produced around 1994
