NAP 250? Don’t see it on the website.
Not difficult is it?
The website is a bit confusing as if you navigate to the Classic Series page it only shows you a small selection of products. You then have to select ‘see all in range’ before scrolling down to loads more products in order to see the rest.
You know as well as I Chris, a Naim site redesign is in the works and long overdue.
