Hi @jsaudio
I had the 300DR and now 500DR.
I bought both amps new and compared them, side by side, in my own system.
For me, the 500DR is immensely above the 300DR.
It brings a lot more details, has a much lower noise floor.
It performs admirably well with complex music like classical.
When it comes to big orchestras the 500DR has a massively better ability to picture the orchestra, whereas the 300DR is blurrier.
But I well understand you may prefer the 300DR. Both amps are brilliant.
For me, the 500DR made THE difference.
Acoustic music is something delicate. If something is not right you notice it immediately. For me the 300DR was very good, but the 500DR sounded closer to the real thing.
Some think the 500DR is just about power. Well itās not. Whatever speakers it drives, smaller or bigger ones, they all benefit from it.
It brought complex music like piano, voices, cellos, etc. to another level
That said, if it is the 300DR that brings a smile to your face, than the better amp is the 300DR. No discussion. And lucky you, the 300DR is a lot cheaper!
NOTA :
Here are my first impressions when I swapped the 300DR with the 500DR
