Nap 300dr what's in each box
Hi guys, just asking when you open the two boxes for this amp what exactly comes in each box cable wise? doo the power,burndy and xor to din all come in one box etc
I’ve just unpacked my new 300
300HU no cables
300PS Power lead, Burndies and XLR-DIN
Thanks for the info guys, much appreciated. I was a little worried heheh can’t wait to get the power supply then I can hook it all up. I’m going from a 15 year old non serviced nap200! I imagine that I may have a slight uplift in SQ even from cold with no hours :sunglasses:
Where’s the 300PS ?
Also, did you use the 200 to power your preamp if so you will need a power supply
As a recent new owner of a 300DR, you need to make sure you use the correct Burndys and XLRs for each channel. They are marked/colour coded to indicate which is for each channel. If you put them in the wrong way around you will get no sound and panic you have a dud unit!
There was a postage error and the two boxes are being delivered on different days. I’ve got a hicap already on my nac282
If you don’t notice any different going from a 200 to 300DR, you need to find another hobby! :grinning:
Haha indeed! I’m imagining a massive change straight away and more as the play hours build up. :grin:
My nap300dr all received today and connected up even brand new zero hours and cold it’s a phenomenal upgrade.massivr soundstage,depth,separation and bass.really really nice. Very very musical. And this will just get even better with the play hours too! Chuffed!
From memory, the biggest change I noticed from new was, there has always been talk about how the 300DR was superior to my previous 250DR at low levels as its much fuller sounding. From new, I didn’t notice much difference between the two, it wasn’t till a few weeks later I went for my second listen & the difference in low levels were very apparent.
Much fuller sounding is a really good description. I experienced the same :+1:
