Bart, I’m sure you will remember me suggesting a 300 to you, and you saying no. I bet you are pleased you went for it in the end. It really is a stunningly good power amp. The head unit is the only standard sized classic box with no buttons, which somehow looks really good.
True indeed. I wanted to avoid more boxes and 2 stacks of Fraim, but now I know! It’s really quite different than the 250DR. I was fortunate to find one “gently used” from a good home!
Get a grip…you know its a NAP500😎
…and you can just cut that out too! I have spent all my money on Amos Lee albums and concerts!
Before servicing olive 250’s I home demoed the 250DR and 300DR, both were better than my 250s, but the 300DR was a big step up.
I’ve wondered if the product name (pardon the pun) is something that makes us expect only a small incremental upgrade - 250DR to 300DR, doesn’t sound much but when you appreciate the different topology and the fact it’s two boxes I think you can understand the reason for the change.
I had other priorities to address first, but the 300DR just seemed to get a grip on the music especially at lower volume levels.
I don’t believe in that list. The Nait 2 should be at the top!
You wants it, you needs it… my precious…c’mon Nigel - resistance is futile - give in to the dark side
You are a bad man, Adam.
Absolutely!
The 300DR does a great job controlling your speakers at low volume levels! That’s one reason, out of many, I chose it over the 250DR
You are not wrong in your assessment Alley_Cat with listening at lower volume levels.
Steve@
All you need is a NAP250DR
SN2 Rules.
Can you connect a NAC 202 with HiCAP to a 300DR?
You can, though it wouldn’t be a particularly sensible long term combination.
When I changed from 202/200 to 202/250 the improvement was far less than when I went 282/250. So I’d be inclined to support the view of @anon4489532 regarding using 300DR with a 202.
Aside from @frenchrooster, there’s not much discussion here on how the 300DR works with the room. I have a 252/SCDR/250DR and I’m interested in a 300DR. I’m keen to hear a lot more detail at low listening levels that the 300 offers. I do have concerns though about excessive bass and my system being thrown out of balance, particularly given my small listening room at 3.5m x 3.5m. Is anyone using a 300DR in a smallish room?
Yes and it sounds superb with exactly your set up. Biggest difference from 250DR for me was the intricacies and detail at lower volume.
My room is 3.6 by 5m. No bass issues at all, but then I have speakers with a very tight bass anyway.
3.5 x 4.5, PMC25:26 on a 300DR no bass issues here either and great for low level listening.
