If a nap 500 has been serviced in the last year will it have the latest transistors installed. It is a 2002 model. Thinking of upgrading from the 300 set up.
That depends; if you mean will it have had a DR upgrade, then not necessarily. However, bear in mind that a freshly serviced pre-DR NAP500 is still a formidable power amp.
