Quick question to my learned colleagues. Which one on bottom if stacked?
If you had to stack I would assume power amp on the bottom.
What speakers are you using (not related to your question just curios as I was considering a qute with Neat Iotas )
Gary
Hi Gary, I have got Dynaudio DM/7 which are a good match. Used to own a Nait 5 with Dynaudio Audience years ago and have stuck with them ever since. Note they are 4 ohm so you get 45W out of Qute, or 75W out of NAP100 which I bought 10 mintes ago!
Steve
When I had that set up I used a set of Guru Juniora which were superb
I have this setup unitiqute2 with Nap100 and PMC5.23. it works good, but right now im looking for if its convinient to upgrade to another amp… NAP200 for example.
Guru Junior are a superb speaker and work really well in many situations.
