I recently acquired a Olive NAP 250 with a NA-48 4-pin DIN to XLR cable. The Amp is being serviced, and I have the cable. Looking at it, I suspect someone has repaired it in the past. The cable is not all the way into the shroud. I took off the shroud and could see that the pins are purple on the solder end where the heat of a resolder job may have discoloured it. The cable appears to work fine, but can I trouble you for help on what to do?
Would you replace it?
If yes, what will be the current cable I should order? Still NA-48?
How would the cable normally have been clamped to the shroud, or is it supposed to be free?
@Suedkiez yes there was a screw, but it looks like I would have to resolder as it looks like they just cut back too much outer insulation when they did it
Thanks for all your advice. Whilst I could solder myself, I will always wonder if the SQ is lost in some way due to this suspect cable, so I have ended up buying a new one, and will keep this as a spare - Thank you all again
i’ve had 6 DIN to XLR cables now between 2 250s and a 4 135s, every one of then was just the same at the XLR end, it’s just a crap designed plug, There’s no shielding or anything so it the terminals are still soldered properly you’re good to go
I’ve thought about it often but as yet all my cabling has remained as supplied. I have been looking at the offerings from Witch Hat, screening would seem to make sense, especially seeing as Naim are offering screened cables as an extra these days, maybe I’ll pull the trigger one day?
The lightweight plastic XLR Cannon plug (Naim’s own) was introduced later on - Naim developed it specifically that way as it sounded better than the big heavy metal ones.
