Sorry if this has been asked before! I just want to know, in a 2 rack Fraim system – should a 250DR be part of brain or brawn rack. I suspect brain – but then again, it has huge xformer, so just wondered
many thanks
enjoy/ken
many thanks
enjoy/ken
Generally speaking, transformers are brawn and head units are brains.
thanks. suppose it could go either as the 250 is a combination of head unit and its power supply in one box.
enjoy/ken
The transformer in the NAP250DR is HUGE! Definitely brawn…
Wot? Bigger than the one in the NAP500 head unit?
Thanks Richard!!! Brawn it will be then…
enjoy/ken
They’re basically pretty much the same size Ken.
Richard, many thanks…
So, the NAP250DR will NOT go where the NAP500 h/u is in the left rack. The space created by the 500PS will create a level for the 250 – probably above the 2 x 555PS DR in the bottom shelves of the brawn rack on the right.
Oh my, what fun!
enjoy/ken
Looks good Ken. Did you manage to move your 500 on ok?
Best
Dave
I used to run my 250-2 in the brawn rack but when my 500 went in for DRing I couldn’t be bothered to rearrange the speaker cables so just replaced the head unit with the 250. Can’t say it caused too much havoc at the bottom of the brains.
