Similar story here - I have a mix of full Fraim shelves and Lites, but I have upgraded the Lites with Naim glass, cups and ball bearings. We have very uneven floors from where the previous owner sanded them far too aggressively. I have found it extremely difficult to get the base level both horizontally and from the back to the front. Nearly exact but a smidge off and I have tried so many times I do not have the patience anymore. I have also painfully stabbed myself a few times with the spikes by accident
Like you, I find the easiest way to dust and clean is to take it apart level by level and then re-assemble. I try to do at least once every two months as I think it is good to avoid too much dust accumulating, plus it looks a lot better and taking the cables in and out is a good way to ‘clean’ them I hear.
I think they have nailed it with the Fraim. Why change a winning design
I’m clearly not caught on the treadmill - 82 for c12 years, 252 for 5 years before 552 - can’t resist a bargain and this was, ex-dem, 135s maybe 15+ and only went when due a service!
…just don’t think of the £££s!
Pleased Dan you and others are enjoying your own box swaps.
I wouldn’t disagree with your comment, I guess I was trying to be somewhat subtle, that at the level of NDX2/252/300 that’s a good balance. Add 552DR, nice jump up, then of course ND555 and that all requires budget as we all know. Of course a single PS is fine.
My “worth” was that when another upgrade exists, it isn’t easy for some to resist, my approach is a vfm one. I never got on with NDS v NDX, although I thought at the time that one of NDS or PS was under performing, so when next gen ND555 was released in due course, a more natural upgrade path.
Yes you need to be patient and carefully check things out…I picked up my Nap500 from Italy…got it for under 5k… I then had it fully DR updated and recapped…giving me effectively a new amp…my best purchase to date…
I understand better now and agree the 252/NDX2/300 gives me a nice balance. I am already tempted by the 552 I’ve found for just under 6k and I haven’t even got the 300 yet
I’ve decided to wait until I have the 300/555ps and if it’s still available in a few weeks time, I’ll reconsider. It probably won’t be, but that’s a good thing as it takes the temptation away.
Ps. Hifi upgrade addiction should be a new branch of therapy!!
So, the 250DR is gone… Sold for £1600 which is not a great price but I think reasonable. There seems to be a fair few on eBay at a higher price that have been there a while. I’ve purchased the 2017 300DR for £3000 so all in all a very cost effective upgrade. I’m picking it up on the 31st so relying on my very capable KEF LSXII speakers until then
Thanks for the tip. This is a very long thread so I forget; but does it include the lengthy message exchange on using cotton buds to clean them? I will go back through it if so
Thanks Dan, I thought so too. Most of the 300s that come up are quite old, which is a good sign as it shows people do not sell them that often, but this one is relatively new and the guy is only selling as he has moved up to a 500DR. Closes the loop on this story quite nicely I think
Yep, I’ve definitely done very well. I don’t think I would have been able to afford any of the components in my system without eBay. I’ve consistently got great deals on fairly new items at c30-40% of the RRP
