One of the two batteriers in my Narcom 4 has leaked and is stuck in the remote. How can I dismantle the remote in order to remove the battery?
Thanks,
Dre
With a thin knife perhaps ?
I sprayed the battery and case with lock spray and later on could pull the battery out of the case with a small plier. TNo need to dismantle the remote
Tomorrow I’ll buy some AAA batteries. Thanks.
