@marksnaim Thanks, I suspected as much… odd that it still works the way that I have it connected. I’ve always wondered about Naim’s insistence that the audio signal be routed through the power supply…
It’ll still work fine, in that you’ll get audio out on the DIN4 socket on the head unit using a DIN4-5 interconnect.
I presume (if the AM head had ever been produced) the multi head PST Tuner selector dial was designed to switch power to the appropriate DIN7 output. It would also route the audio signal coming back from the DIN4 on the powered head unit to the DIN5 output on the PST, connecting to the preamp via a standard DIN5 interconnect.
I think the TV tuner idea pre-dated NICAM. The AM tuner was doubtless too late in the day, even with the promise of AM Stereo in the States, which didn’t really take off in any big way.
I remember having a demo of the Arcam Nicam tuner. I recall that I was quite impressed, but not enough to actually go out and buy one. Interesting to think that at the time Arcam had quite a system to offer in their Delta range, entailing not just a great CD source, but a separate DAC, great tuner, pre-power amp (and a couple of integrated amp options), a Nicam tuner, a top class cassette deck, and speakers. I still regularly use a Delta 80 tuner, and Delta 90 and Delta 60 amps and they have been super-reliable.
Interesting. I wonder if the more direct route actually sounds better? I don’t use the NAT01 very often for critical listening, more as background with R3, but I might experiment because it’s a simpler arrangement.
Worth trying, Mark if you have a spare DIN 4-5 cable. You’re eliminating a number of unnecessary items in the audio signal path - cable, connectors and selector switch.
Naim did that themselves with the later NAT01 with the single output NAPST. The audio output is straight from a DIN5 on the head unit (as shown in RWCs post).
