Can you use a Flatcap 2 on a NAT 05, and if so does it give a good boost to the sound (which is already excellent!). I know that you can with the NAT 05 XS but can you with the earlier non XS variant? Thanks in advance.
No, you can’t add a dedicated power supply to the NAT05.
Thanks. Sounds great as it is anyway
