Thanks again all. I confess I thought it was somewhere on this forum that I’d seen a remark about not servicing NAT01s any more, while I was reading through before starting this thread. So thank you graham55, that’s good news. The 4 element aerial is in the roof, so isn’t subject to the weather, and I’ve re-stripped and reattached the coax at the aerial end, and done the same at the wall plate (PAL socket) in my music room. When the flip happens, the stereo dart under the signal dart just goes out, and I’m reasonably sure it affects all stations, including Radio 4 and Classic FM, although yes, I do mostly listen to Radio 3. There appears to be no change in background noise, which is very low - i.e. the stereo doesn’t get hissier before the flip, but I think that’s a tribute to the Naim design and the threshold set for the balance between signal strength and the switch to mono. The focus on the cable in this thread makes me wonder if the coax could have been damaged somewhere along its length, e.g. by mice in the wall, which I have had occasionally (you have to take humane traps a very long way away to stop them coming back). Trying a new cable run might help identify the problem, but still wouldn’t explain why it’s intermittent. And thank you Skeptikal for the suggestion that I try the NAT where the Creek is - I’m using the DIN output on the Creek, so that would be fairly straightforward. I’ll swap them over. I suspect that might also reveal how good the Creek is, even if it doesn’t quite have the extraordinarily natural quality of the NAT.
Charlie, bear in mind that the NAT01 trades sensitivity for selectivity, so will likely need a stronger signal than the Creek to reach the stereo threshold and full quieting. This is why Naim recommended it be used with a Galaxy aerial.
Thanks Neil for clarifying here.
Possible NAT01 issues aside, as you mention you have a Galaxy as a spare, perhaps it’s worth contacting Ron Smith Aerials (IIRC his Son runs it now) and get them to come out an install it and run a new length of coax in too. At least you know it’ll be installed and aligned correctly by someone who knows what they are doing and allow you to get the best quality signal for the NAT01.
Ron Smith disappeared off to Spain, I think, some years ago. It’s good news indeed if his son has got the business up and running again. I live right on the south coast and my aerial has taken a bit of a battering from high winds since it was installed over ten years ago.
I will buy a brand new one, if that’s possible. I’ll see if I can find them online.
PS I found the site online, and have left a message asking if they can help.
I recently bought a Nat01. Had both boxes serviced before the dealer installed it. I have a loft Ron Smith Circular 5 which is one of their smallest but nevertheless my tuner is wonderful. To me intermittent problems sounds like the Nat 01 needs servicing more than a problem with aerials cabling.
It is a lovely bit of kit, but at ten years since its last service it may well need some TLC at Salisbury, please remember this is a piece from the last century .
Even if you want to get rid of it, have it serviced as it will be very sellable
Graham, Ron passed away in 2010. George has been based in Spain for a very long time, iirc.
Mail order is still available and the website is still live and the aerials are now available in kit form (for shipping). I can imagine being by the coast takes its toll.
RS rigged my G17 a quarter of a century ago and it is still going strong, I had met him a few times for different rigs, a Puccini fan, iirc. The coax lead has subsequently been replaced after water ingress, which George suggested might have occurred when we discussed the matter by phone. I eventually found a great guy locally, well experienced with radio aerials.
Thanks, I’ve amended my earlier post to say that I found the site and I have left a message asking for their assistance.
Rowridge is undergoing essential maintenance at the moment and is on reduced power.
I am line of sight of Rowridge and it has been up and down of late.
Below is from BBC check transmitter faults.
|From 10:02AM on 7th May 2024|BBC Radio 1|Slightly reduced power due to essential engineering|
|From 10:01AM to 11:46AM on 4th May 2024|BBC Radio 1|Slightly reduced power due to essential engineering|
|From 10:02AM on 7th May 2024|BBC Radio 2|Slightly reduced power due to essential engineering|
|From 10:01AM to 11:46AM on 4th May 2024|BBC Radio 2|Slightly reduced power due to essential engineering|
|From 10:02AM on 7th May 2024|BBC Radio 3|Slightly reduced power due to essential engineering|
|From 10:01AM to 11:46AM on 4th May 2024|BBC Radio 3|Slightly reduced power due to essential engineering|
|From 10:02AM on 7th May 2024|BBC Radio 4|Slightly reduced power due to essential engineering|
|From 10:01AM to 11:46AM on 4th May 2024|BBC Radio 4|Slightly reduced power due to essential engineering|
|From 10:02AM on 7th May 2024|BBC Radio Solent|Slightly reduced power due to essential engineering|
I was in touch with George Smith in Spain as recently as last year - as responsive and helpful as ever. I bought the G17 when I acquired the NAT01, but never installed it as the tuner worked perfectly with my old 4-element aerial - until late 2022.
NeilS thank you for confirming it can still be serviced. Worth doing while it can still be done. I never mind a trip down to Salisbury, as it reminds me of the happy days when I was able to drop down and chat with the great JV himself - including about folding bikes, yachts etc… And a service now will probably see it through until the fateful day when they do go ahead with switch-off.
I’d love to get the G17 up, but it won’t fit in the loft where the 4-element is. We built our house in a period style, and it is so far unadorned with aerials, so there’s a WAF issue here. I’d have to send her off on a boozy lunch with her chums and hope she didn’t notice when she got back; though there’s one gully I might be able to partially hide it in.
In the meantime I’ll try a run of new WF100 - George warned me it’s hard to get “real” CT100 any more, as much of it is fake and uses inferior metal.
Kend I think you might have nailed it for me. I was about to suggest that the NAT01 flips to mono when the sky is clear: I’ve had good stereo reception all weekend, during the cloud and rain, and this beautiful clear blue morning it’s mono again. I couldn’t understand that. But I can understand the impact of reduced power!
Justin at aerialsandtv is another gem of the industry - and thank you Skeptikal, that’s indeed where I’ll get the WF100.
Here is an anectdotal story about my NAT-01 experience when I relocated to South Florida.
When I first moved here about 12 years ago, there was only one FM station worth listening to…a classical station in Miami. But it was a good distance away.
Nevermind, I have a G17.
But…
…Home owners Rule #5…no roof mounted antennas.
Well there was no rule about sticking them on a ladder and putting it in the backyard, which is exactly which I did. But the line of sight was partially obscured by trees and after ages, the best I could do was to get a relatively hiss-free mono signal and that stereo ‘dart’ indicator would not light up.
But one day, after a strong windstorm…the stereo indicator lit up for the first time, and I was getting glorious stereo sound. So I went outside to see what had changed.
The wind had blown the antenna and turned it by 90 degrees. It turns out the radio station was vertically polarized and I had set up the antenna for standard horizontal polarization. By a stroke of serendipidy my fortunes were reversed.
Of course 6 months later, the radio station shut down and was replaced by a Christian music station.
At which point I removed the G17, the ladder and the NAT01, which now has now been on long term loan to someone I know for the last 4 years.
Having a weaker signal with clear skies is to be both theoretically and practically expected…the clouds are not there to bounce the signal back to earth and it just gets radiated to the stratosphere.
Very interesting. I think most uk stations are horizontally polarised and I don’t think I have seen an installed Galaxie in vertical orientation.
I just dug out RS’s aerial guide and he suggests most main transmission are horizontal and local repeaters are vertical - it fails to clarify if that refers (in general) to uk.
I remember Ron had fitted on his shop, what was either a Galaxie 26/29 or 32 - which I doubt anyone used to feed a NAT01. The rig was triple masted and I think, triple or quad guy wired, all for stability.
The guide describes a G29 located in the Dordogne, achieving good regular reception of R3 !
The guide isn’t dated but likely >25yrs.
Who I wonder, can recall which model Galaxie still is doing duty at Southampton Road - I believe there may be more than one?
Apologies to the OP for the “drift” !
I’m interested that there’s a link between clear skies and a weaker signal. In trying to find a pattern in the tuner’s behaviour, I had picked up a possible connection. But after kend’s very helpful post - I have bookmarked that webpage, as I’d looked for it but failed to find it - I was beginning to think the link to clear weather was because that’s when they could carry out essential engineering on the mast.
I have a wonderful golden-eared friend who lives in Virginia, close to Washington DC, and is a great fan of the NAT01. He envies us the fact that there are still a few good stations in the UK broadcasting in stereo. I’ve hooked an iPad into my system to compare the FM signal through the NAT with BBC sounds. I’m afraid it’s no contest, even when FM is delivering mono.
Rowridge is horizontal for FM, as I understand it, but both horizontal and vertical for telly - I believe to help customers who are getting interference from France. Justin at ATS suggested I try my TV aerial vertically, even though it wasn’t a Group A aerial, before buying a new one from him
The ones on the factory are Galaxie 23s, there are four of them. I don’t know if they are currently all in use though.
I can recall seeing Ron’s American van parked beneath & him shimmying up the triple masts with no safety gear in sight! Old skool
Neil.
Hmmmm…my NAT01 has been resident in Virginia, close to DC for the last few years.
Could this be the same person of RSL??
Rowridge and all the main national/regional FM broadcast transmitters in UK are ‘mixed’ (also called ‘circular’) polarity. Local infill transmitters are mostly vertical only.
