@Richard.Dane - Hoping you can clarify the replacements I need to order for my NBL’s. I’ve found two different sets and unsure of which ones to order. It’s been a busy week for you and all the updates on the new gear has been awesome.
This one seems to be the original…
willys-hifi scanspeak-classic-d2010-851100-tweeter
This is one on a U.S. website but only has three holes for screws…
madisoundspeakerstore scanspeak/scanspeak-d2008/8511-3/4-textile-dome-tweeter/
This one seems like a new one offered…
willys-hifi scanspeak-d2010-852100-classic-range
They have discontinued the original and has been replaced with an updated version, which as I understand needs a slightly different sized hole. I am sure someone can clarify.
Ordered yesterday, thanks everyone! See how long it takes to get to the U.S. As far as assembly/replacement, is it something I can do or should take to a dealer?
