I’m going to plan on picking up a NC 250 for my Nova this week. I wanted to try it out in the main system as well. Would the Chord Music XLR-Din connections I use now with my 500 DR also work with NC 250 to connect to my 552 DR PS?
There is a ‘compatibility & cable information’ pdf file floating around but I do not have the link.
The 552 is not listed on the compatibility chart.
No the connections are wired differently. You’ll need the appropriate adapter cables. Type 7 should do it but your dealer will be able to advise.
ok, thank you. I’ll have to ask them as well.
Will be interested in your findings please.
Sure thing. I’ll see if I can source the 250 and appropriate cables as well. Too bad you couldn’t just use existing Din-XLR cables (Superlumina, Chord, etc.)
