Can anyone answer why when I alter the display dimming on the Naim App it only changes the display on my 333/332/NPX300 to either low/medium/high and not on my 2 350’s it’s the same on the remote for the 333. If I use the remote for the 332 all is ok. The 333/332 are paired wirelessly and the 350’s are connected to the 332 via the supplied remote cables. Are the 350’s out of sync if so how do I re-sync them. Or do I need to connect the 333 to the 332 with a cable.
Switch it all off at the wall, switch the wall socket back on, then take the system out of standby by pressing the On button on the 332 (not 333).
Hi thanks for the advice, presuming everything is set to standby before switching off at the wall socket.
