Last time I did update from 3.8.0 to 3.8.1 and I feel I did mistake again …
I remember 3.7.1 was the worst sounding firmware but 3.8.1. is also worse sounding then predecessor …
3.8.1 is much better then 3.7.1 but again not as good as 3.8.0 and 3.7.0 …
I noticed following differences;
flat sound
quieter
sound is little muted
less pronounced
less open
more heavy on middle bass
more delicate (but I do not like it)
bass is not as deep as it was on 3.8.0.
3.8.0 in terms of sound quality was much better in my system!!!
Something wrong with my ND555 which is very sensitive to firmware changes???
I really would like to have my ND555 sounding like on the beginning …
I’ve found many of the update versions sounded a little different and some I did not like, but settled-down and came good in my system.
I do find - for me in my system - these updates seem to take a few days to settle-in and sound good.
What is happening - does the update process stress things or am I getting used to it - or both unknown.
There is more low-bass definition - a lot more and that can stress system set-up with more LF energy so worth re-checking all those system set-up things.
