ND5 XS 2 Switching Off Mid Play-Back
I have a 2023 ND5 XS 2 which, until recently, has been working very well. I feed it into a Naim DAC + NAC 252 + NAP 300 DR.
In the last couple of days, the ND5 XS 2 has been switching itself off during play-back. I can switch it back on at the front and it then plays for a bit before switching off again.
Has anyone encountered this behaviour, and does anyone know how to deal with it? I suspect it could be connected with auto-standby, which should only happen after a decent period of idleness but is perhaps now happening at random?
Hopefully I can correct the problem myself, as I fear I may be just out of warranty but too soon for routine service.
Hi, do you have this problem on all inputs?
Does it still happen if you set Auto Standby to Never?
If it is switching off entirely, then possibly the same power switch problem which has occurred with a few Naim items. The on / off button can fail to latch properly. Usually it results in units not powering up though, but I’m thinking it could possibly be this. Whilst I’m not saying this is the issue, it may be worth a quick experiment to see if it is.
In case you are not aware, the time honoured method to rectify this is pretty basic. Disconnect the power lead completely and then, with the rubber eraser end of a pencil, give the on off button several fairly firm pushes. It might not be the problem but worth a try as it will take only a few minutes.
Good thinking, Steve. Unfortunately it’s not a latching switch like the Power amps and PSUs which can suffer the issue you mention, but just a momentary action switch which brings the unit in and out of standby (there is no mains on/off switch as such on the ND5XS2).
I wonder whether @NeilS has encountered this issue before?
I should have thought that. Scrub my last @endlessnessism !
What’s happening seems to be a full switch-off, not just standby - the green Naim badge goes off - but I can switch it back on with the button at the front. If it’s a full switch-off, that may suggest a hardware issue rather than software.
I have just updated the firmware and will keep it under observation. As I use Roon for control rather than the Naim app, I don’t check for updates regularly enough. I’ll have to correct that habit.
I haven’t - a strange one.
@endlessnessism do report back if it continues to happen.
Neil.
Fingers crossed, the problem may have resolved itself. The switch-off happened five or six times yesterday but not at all today. I have (1) installed the latest software and (2) switched off and back on at the wall, but whether either of those things had an effect is impossible to say. Honestly, I don’t know which is more frustrating: a problem that arises for no apparent reason, or a problem that resolves itself and you’re none the wiser.
